Poltergeist: Remote Control Overlay & Mod Tools
Heek Development updated Poltergeist: Remote Control Overlay & Mod Tools with a new update entry:
Chatbot Clips & Custom Widget
Twitch Auto-Clipping & Dashboard Polish​
A new clip command was added to the chatbot and the custom code widget no longer shows CPU lock when going to a different tab
  • Auto-Clipping: You can now create automatic Twitch clipping commands (like !clip) directly in the Chatbot Builder! Just check the "Create Twitch Clip" box and add the {clip_url} variable to your bot's response to instantly drop the clip link in chat.
  • Custom Widget Stability:...
Kick chatbot
Kick Chatbot Integration​
Kick broadcasters who have the broadcast suite can now fully utilize the Chatbot Builder!
  • Custom Commands & Timers: Build custom chat commands, set up automated looping messages, and configure mod-only triggers that reply natively in your Kick channel.
  • Chat-Driven Games: Your viewers can now interact with the Prize Wheel and Carnival Booth directly through Kick chat using commands like !spin or !throw.
The...
Moderator "Soft-Locking"
Moderator Limits Revamped​
Moderator limits have been completely updated for expired Broadcast Suite subscriptions and 7-Day Trials. Previously, reverting to the Free tier (which has a 1-moderator limit) meant the system automatically deleted any excess moderators. This proved to be a frustrating experience.
No More Deletions​
Moving forward, excess moderators are no longer deleted. Instead, they are simply placed in a locked state. A red LOCKED...
Trigger Studio
Trigger Studio: Put Your Viewers in Control​
Trigger Studio is a brand new automation panel that turns viewer activity into automatic on-screen moments. Map an event to an action and it fires by itself, with no moderator needed. Open it from the Trigger Studio button in the right sidebar, name your trigger, pick what fires it, then pick what happens on screen.
  • Fires from anything: Channel Point redemptions, Bits, Subs, Gifted Subs, Raids, or...
Native Follow & Channel Point Alerts
Follow & Channel Point Alerts Go Fully Native​
Follow alerts now run natively through the Poltergeist backend on both Twitch and Kick, with no external chat bot required. Detection happens automatically the moment someone follows, so tools like Botrix or StreamElements are no longer part of the setup. Channel point reward redemptions now drive alerts on Kick too, matching what has long been available on Twitch.
  • No external bot: Follow alerts fire on...
Media Share Clips
Media Share Now Plays Twitch & Kick Clips​
Media Share is no longer YouTube-only. Viewers can now spend Bits or redeem Channel Points to put Twitch and Kick clips on your screen, right alongside YouTube videos. Same queue, same approval flow, same cost-per-second controls. Paste the clip link and it just plays.
  • Twitch Clips: Drop any clips.twitch.tv or twitch.tv/.../clip/... link and it plays in the queue like any other request.
  • Kick Clips: Kick...
Trigger Studio Update
Animate multiple elements at once​
The Animate action now supports selecting more than one element. Hold Ctrl (or Cmd on Mac) while clicking to pick multiple.
A new Playback option controls how they fire:
  • Animate all selected together: every chosen element fires at the same time.
  • Animate one at random: a single element from the selection plays each time the trigger fires.
Play multiple sounds (one...​
Custom Pen Colours for the Telestrator
Telestrate in any colour​
The pen is no longer locked to green. Open the Tools panel, click the Colour swatch, and choose any colour from the full picker.
  • The colour applies instantly, both on the dashboard and live on stream.
  • Switch colours as often as you like. Each new stroke uses the latest pick, so it is easy to colour code plays, callouts, and reactions.
  • Works for you and any trusted mods drawing over your stream.
Drawings Get another Upgrade
Drawing Tool: Adjustable Size, Staging, and Saved Strokes​
The telestration pen is no longer a fixed-width line locked to the live area. Set the stroke width, sketch in the staging area before anything goes public, and keep your drawings when you push, swap, or save a scene. Strokes now move with your layout, and every one of them is validated on the server.
  • Adjustable stroke width: A size slider sets pen thickness from 1 to 50 px, and your choice is...
More Trigger Studio Features
Trigger Studio: Sub Timers, Chat Commands, Hype Trains & Sequences​
Trigger Studio grew into a full automation layer. Run a subathon timer, fire overlay actions straight from chat, react to Hype Trains and stream status, chain assets into each other, and pace it all with cooldowns, chances, and delays.
  • Sub Timer: Point a trigger at a countdown Timer and every sub, gift, or cheer extends the clock. Gifted subs add time once per sub (a 20-sub bomb counts 20...
Permanent Overlay URLs
Rename-Proof Overlay Links​
Overlay links are now permanent. When you open "Get Link" from the left sidebar, the generated URL carries a private overlay ID tied to your account instead of your channel name.
The result is a URL like:
https://poltergeist.cc/overlay?channel=YOURTOKEN&platform=twitch&interp=true&lerp=0.5
This means the Browser Source in OBS keeps working no matter what happens to your username.
  • Rename-Proof:...
Referral Program
Get Free Broadcast Suite Days for Referring Streamers​
A new "REFERRAL AREA" button in the left sidebar of the dashboard opens your personal referral link, your referral stats, and the new leaderboard. Share the link anywhere. When someone signs up through it and subscribes to the Broadcast Suite, free days are added to your account automatically.
https://poltergeist.cc/?ref=yourcode
This means bringing fellow streamers to...
Interactive Dashboard Tutorial
Learn the Dashboard Hands-On​
The dashboard now includes a guided tutorial for streamers and moderators. It starts automatically on your first visit, and can be replayed any time by clicking the "?" button in the bottom right of the canvas and choosing "Restart Tutorial". Pick the tour that matches how you use the dashboard, and it walks through every section in order, from OBS setup and the Live and Staging zones to the Soundboard and the builders.
This...
Combined Chat Custom CSS
Restyle the Combined Chat Feed​
The Combined Chat asset now has a "Custom CSS" field in its properties panel. Write your own CSS, press "APPLY STYLE", and the new look shows up in the dashboard preview and in OBS. This means your chat can match your stream's branding instead of the default look. The following classes can be targeted:
  • .chat-message-row - a full chat message
  • .chat-user - the username
  • .chat-text - the message text...
Chatbot Response Variables
Smarter Chatbot Responses​
The "Chatbot Builder" (right sidebar, under the Animation Timeline) now fills responses with what viewers actually type, and every command gains two new controls: an "Availability" dropdown and a "Mods & Broadcaster skip cooldowns" checkbox.
Commands: {command_list} on a !commands command posts a live list of every enabled command, and Go follow {target} at {so_url}! They were last seen playing {so_game} turns one command...
Custom Element Names
Give Your Assets Readable Names​
Every asset on the canvas has a unique name starting with el_. The new "Element Name" field at the top of the right sidebar properties panel lets you rename any selected asset to something readable, like el_maincam or el_donation_goal. Type the new name, press Enter, and it applies everywhere at once.
This makes assets much easier to pick out in Trigger Studio dropdowns, the Animation Timeline, and anywhere else asset names appear...
Custom Variables
Live Values Anything on Your Overlay Can Read​
Overlays can now hold named values that events and chat rewrite mid-stream. Create one in the new "Custom Variables" window in the sidebar, or under any Custom Code widget's code box, then read it with a token.
<div>Boss HP: {var:bosshp}</div>
Death counters, subathon goals, boss bars, win/loss records: a few lines of HTML, or just a Text element, driven from Trigger Studio.
  • Event...
Moderator Invitations
Moderators Are Now Invite Based​
Adding someone in "Manage Mods" now sends an invitation instead of granting access straight away, so a mistyped username never reaches a stranger.
  • Invite: enter a username and click "Add". The entry sits in the list marked "INVITED", and if the user exists a notification arrives on the dashboard.
  • Answer: invitations appear in the new "Moderator invitations" panel, ready to accept or...
Two-Factor Authentication for Enterprise
Sign In With an Authenticator Code​
Enterprise accounts now have a "2FA" link next to "PASSWORD" in the left sidebar. Set it up with any authenticator app, and an operator password on its own is no longer enough to reach a live dashboard.
  • App Setup: Scan the code in the "2FA" window, or type the Setup Key into apps that cannot scan.
  • Recovery Codes: Ten single-use codes are issued at setup for when the app is out of...
