Poltergeist: Remote Control Overlay & Mod Tools
MrGoatsy submitted a new resource:
Poltergeist: Remote Control Overlay & Mod Tools - A collaborative production suite built for Twitch.
Poltergeist is a production tool that allows streamers to offload overlay management to their moderators. It creates a collaborative environment where your trusted team can interact with your stream visualization in real time, without needing access to your streaming PC.
The Goal
The purpose of this tool is to enable live production capabilities, such as real time annotation and dynamic asset management, without the streamer needing to lose focus...
MrGoatsy updated Poltergeist: Remote Control Overlay & Mod Tools with a new update entry:
KEYFRAME ANIMATION ENGINE
We have deployed a new module to the dashboard that allows for native timeline-based animations.
New Features:
  • Timeline Editor: A collapsible timeline panel hos been added to the interface.
  • Property Interpolation: You can now keyframe Position, scale, Rotation, and opacity values.
  • Live Sync: Playback is synchronized in real-time between the dashboard and the OBS overlay.
  • Controls: Includes drag-and-drop keyframe adjustment, looping toggles, and manual scrubbing.
To...
Soundboard upgrade
LIVE POLLS, EVENT ALERTS & EDITOR IMPROVEMENTS
New Feature: Live Chat Polls
Engage your chat with the new Live Poll widget. Ask a question, set your options, and viewers can vote by typing !vote 1, !vote 2, etc., in chat. The on-screen bar chart will dynamically update in real time.
  • Customize the color of each bar individually.
  • Pause, reopen, and reset votes with a single click.
New Feature: Event Alert Box
You can now display on-screen alerts for...
Asset Duplication
A new quality-of-life feature is live! You no longer have to manually recreate text styles, custom shapes, or complex alert boxes from scratch.
Asset DuplicationYou can now instantly clone any asset directly on your canvas.
  • Select any asset (or group of assets) on your canvas.
  • Scroll to the bottom of the right sidebar and click the Duplicate button.
  • An exact clone will spawn directly next to the original.
What gets cloned?Everything. The new asset perfectly copies...
Heek Development updated Poltergeist: Remote Control Overlay & Mod Tools with a new update entry:
Chatbot Builder
The Chatbot Builder is now available as part of the Broadcast Suite.
Create custom chat commands that are handled server-side — no third-party bot required.
To get started:
  • Open the Chatbot Builder from your dashboard.
  • Mod "PoltergeistCC" on your Twitch channel.
  • Create a new command and hit Save Settings.
Command options:
  • Trigger Type: Chat Command (e.g. !discord)
  • Response: The bot's reply. Supports variables: {user}...
Public Gift Link
A Copy Public Gift Link button has been added to the right sidebar of your dashboard.
Your public gift page allows anyone to purchase Broadcast Suite access for your channel directly, without needing to be one of your moderators. This makes it much easier to share with your community.
To use it:
  • Open your dashboard and make sure no assets are selected.
  • Scroll to the bottom of the right sidebar.
  • Click Copy Public Gift Link.
  • Share the copied link...
Chatbot Expansion & Free Native Alerts
Native Follow Alerts are now Free​
The Poltergeist Native Bot is now officially unlocked for all Starter Kit (Free) users.
There is no longer a need to rely on third-party bot names to catch follows. Simply check the "Use Poltergeist Native Bot" box in the Alert Box settings to get instant, reliable follow notifications directly through the system.
The Chatbot Builder Overhaul (Broadcast Suite)​
For Broadcast Suite users, the Chatbot...
New assets: Sub Goals & Event Lists
New Widgets: Progress Goals & Event Lists​
Dynamic widgets for community tracking are now available in the Spawn Assets menu, operating completely automatically behind the scenes.
  • Live Progress Goals: Dynamic Sub, Follower, and Cheer goal bars can now be added to the canvas. These automatically connect to Twitch events and fill up in real-time. Colors, text, and starting/target numbers are fully customizable to match any channel branding.
  • Event...
Layer-Filtered Overlay URLs
Per Layer Overlay Control​
The OBS link generator now includes a layer visibility selector. When you open "Get Link" from the left sidebar, you will find four checkboxes letting you pick which canvas layers are included in the overlay URL before copying it.
The result is a URL like: https://poltergeist.cc/overlay?chan...rp=true&lerp=0.15&layer=1&layer=3
This makes it possible to run multiple...
Media Share via Bits
Media Share & Video Queue​
You can now let viewers share YouTube videos directly on your stream using Twitch Bits. The new Media Share asset handles queuing, playback, and moderation all in one place.
  • Bit-Driven Playback: Set your own "Bits per Second" rate and "Minimum Bits" threshold. Viewers simply add !play [YouTube Link] to their cheer message (e.g., cheer500 !play https://youtu.be/...).
  • ️ Built-In Moderation: Videos...
Custom widgets
Custom HTML, CSS & JS Widgets​
You can now build completely custom widgets directly inside Poltergeist. When you spawn a "Custom Code" asset from the left sidebar, you will get a dedicated code editor in the properties panel where you can write your own HTML, CSS, and JavaScript.
This makes it possible to create highly specific visual elements, animations, or data trackers on the fly without needing external hosting.
  • Secure Sandbox: Custom code...
Better Alerts, Animations & Media Share
Smart Alerts & Advanced Animations​
The Alert Box and Animation Timeline have been significantly expanded to give your stream a massive visual upgrade. When editing your setup, you now have much finer control over exactly what triggers your alerts and how they physically move onto the screen.
For example, you can now set minimum and maximum thresholds. Want a different graphic and sound for 5 gifted subs versus 50? Just set the min/max limits on two different alert...
