Waveform
Waveform 1.8.1
it ended up being a corrupted obs instal. Now to rebuild everything back. the plugin is wonderful and works portable and standard install both.
I'm curious how would one go about making the wave form, 1000x1000 (outer direction) around a image I got, when I set the size to 1000x1000, and change the deadzone, the waves become so tiny it's impossible notice, I wanted have something like NCS has
Yeah so I know it's a bit confusing but in radial mode the 'Height' option controls the diameter of the outer circle and 'Width' controls the width of the graph to be wrapped around the circumference of the deadzone.
With a small deadzone this means you're trying to cram 1000 pixels into a tiny circle so it gets squished. Some combination of increasing deadzone, reducing width, and adjusting the cutoffs (closer together) can help ameliorate this.
You can also reduce 'FFT Size' to make the lobes bigger in exchange for reduced frequency resolution (which can be very noticable at the low end).
Hello everyone. I have a question, I'm using the plugin to monitor some audio signals but when I lower the volume control of the source it keeps showing the same level, is there any way to change that? Or could an option be added to make it work this way in the future? Regards.
Hi, hope this message can reach the solution. I find that the waveform visualizer is only active if the scene is active, if the scene with waveform visualizer is not active, which means the scene is not shown at the moment, even though the video is still playing, the waveform stops. Is there any workaround?
This is by design to avoid wasting resources in the background, but it shouldn't happen if the source is visible anywhere in OBS.
If your really need it to run constantly you can pop out a projection of the source or preview of the scene and that should keep it alive.
Is there some scenario where the source stops even though you can still see it in OBS?
I'm having a problem using the Waveform plugin after my update to OBS 30.3. I was originally using OBS 28.
My setup is ruinning OBS KDE Plasma on Ubuntu on a VPS. I'm broadcasting to Owncast on the same VPS
The scene that works fine in OBS 28 but not OBS 30.2.3 have Waveform source overlaying a VLC Video Source.
When using the Waveform as an overlay to the Video the video and audio stutters in Owncast.
If i run a scene with Waveform source only and not video then everything is fine.
Can I fine tune Waveform or try different settings rather than default for the Waveform source?
Turned out that was not the issue.. Never mind!!
Love the plugin!
Here is the full report
Thanks.
Can you try this beta build and see if it at least averts the crash?
If it doesn't crash but also doesn't render anymore then you probably need to adjust some settings in your waveform source.
If you figure out which setting does it, please let me know so I can fix the validation.
Thanks.
Thank you so much, works great again !!!!
Phandasm submitted a new resource:
Waveform - Music visualizer / spectral analysis
How do i get this to work on OBS on mac os? i have a dropdown on properties, but nothing like what is show in the picture. i just have a white waveform and i cant change colours or any other options. Ive downloaded the waveform and installed it. is there anything else i need to install to get these options?
-- Wow.. i just saw there is a slider and more options here!
Im getting the following message when trying to. install/open Waveform_v1.8.1_MacOS_arm64.pkg on a M2 MacOS Sequoia 15.5.
Please Help!
Please Help!
I actually came here to make a similar comment.
This just means that the ARM version of this plugin is not truly ARM compatible, but still x86 (Intel)
So, can we fix that sometime? ARM Macs have been out for 5 years now, there's no reason this shouldn't be native ARM.
Only 2 suggestions! Add a mirror center or inverted to the Stepped Bars, and add a background color so for example the stepped bars look darker when no sound is playing
Hello everyone. I've tried to go through all the discussion and also to find any other advice or solution around the web, but still not able to have Waveform working on a Mac M4 Sequoia 15.5
I think I did everything was requested in the install process but still not able to see any source called "Waveform" or kinda, in OBS Studio (which is 31.1.2 version). Am I doing anything wrong? Is actually working on this version and all these computer specifications?
Thanks everyone who wants to help. Alex
