Touch Portal
Semi-free Touch Portal 4.0 build 2
touch_portal updated Touch Portal with a new update entry:
Touch Portal 3.0.5
Touch Portal 3.0.5
Uninstall the previous version if you are using a version below 3.0
Make sure you create a BACKUP before proceeding with your update
Just restart Touch Portal to get the notification to update
Windows:
Automatic update from your notifications center
or Download from:
https://www.touch-portal.com/downloads/TouchPortal_Setup_release.exe
Mac:
https://www.touch-portal.com/downloads/TouchPortalMacRelease.dmg...
Hey guys. So I'm having an issue currently.
I have a flow set up and an event linked to that flow. It worked perfectly yesterday, but since I stream tomorrow. I figured I'd test it and make sure everything is still working well tonight.
but it's no longer working?
Like. Touch Portal shows that the event is being triggered but the effect is no longer happening on OBS.
However, the other event I have set up works perfectly still... I'm really new to all of this, please help!
is it possible to connect multiple mobile devices with diffrent screens
for producer screen a
for presenter screen b
Touch Portal 3.0.6 Released!
Touch Portal 3.0.6
Windows:
or Download from:
Mac:...
Touch Portal 3.0.7
Windows
or Download from:
Mac:
This is changed in this new version...
Touch Portal 3.1 build 4
General Changes​
  • Fixed Values parent folder .. selectable and causing issue
  • Fixed Values multiselect and delete not showing folders in list
  • Fixed Values multiselect Values and folders not being able to delete then all at once
  • Fixed global Events parent folder .. selectable and causing issue
  • Fixed global Events multiselect and delete not showing folders in list
  • Fixed global Events multiselect Events and folders not being able to delete then all at...
Touch Portal 3.1 build 6
This is the changelog of build 6 of the 3.1 release. Here is a list of the fixes:
General Changes​
  • Fixed OBS V5-variant Nested scene visibility within groups not triggering events
  • Fixed Flows selection control not rendering with error
  • Fixed Touch Portal services not starting for custom system process
  • Updated the OBS onboarding screen to be correct for V5 plugin integrated with OBS 28
  • Changed default port for OBS to 4455 instead of 4444
  • Fixed OBS...
I've been asked if I could provide a CamooZ plugin for Touch Portal. Here is what CamooZ is all about.
CamooZ homepage
I do not have the time these days to dig into a new SDK and all. In case someone would like to do that though, I'd be happy to share the details as to how to get a list of current camera profiles from CamooZ and how to command to it switch active profiles.
If you're interested, please PM me.
Touch Portal 3.1 build 8
Windows:
or Download from:
Mac:
This is changed in this new...
I'm new to OBS and Touch Portal. Both are fantastic! I'd like to create a button in touch portal to start a fullscreen projector in OBS and send it to a particular monitor. I intend to use this in Zoom and Teams calls for while screen sharing. I can't seem to find documentation for this online or in this forum. Any help is greatly appreciated.
Best,
Jim
I'm also looking for the same. I saw its quite old thread. Did you get the solution !! any luck
Hi guys, i need some help to write a button... Using touch portal pro for a long time. I prefer to use obs in studio mode. and i wonder if there is a way to make a button to do this: on first touch, selected scene comes in the preview window (buttons color turns green), second touch selected scene goes to program (buttons color turns red). i kind of make it happen up to this, but when i press only one time a second button (a same one, with a different scene), the first one wont get back to his "stand by" color. I attached a picture with my button settings etc. Can some one tell me how to make this work?
Touch portal has the command "When obs active scene "is/is not" change to "scene" but unfortunately it has not the "When obs preview scene "is/is not" change to "scene" which would made that easy, i think. Any suggestions?
Thanks
Thanks
Nevermind! Found the solution to that one by using the extended plugin version.
Unfortunately i got a freeze kind issue. Using latest version on obs, touch portal pc and mobile, and after a while touch portal freezes on the tablet. that means it is totaly frozen or i can for example change e scene but the buttons doesnt change state. A restart on the pc touch portal is required to get it unfrozen. Any thoughts?
Touch Portal 3.1 build 12
Change Log
https://www.touch-portal.com/blog/post/version-change-log/change-log-version-3-1-11.php
Windows:
or Download from:
Mac:...
New In Release Version 3.1 build 12
Change Log
Windows:
or Download from:
Mac:...
Touch Portal v4.0 Multi-Device Upgrade and more!
A new version! We changed & added a lot again in version 4.0. Check it out below. The theme this version is missing actions and events! But we have done a lot more as well.
Full change log:
https://www.touch-portal.com/blog/post/version-change-log/change-log-version-4-0.php
New Multiple Devices Upgrade​
With this Upgrade you will be able to connect multiple devices to one Touch Portal desktop. One device, the primary device, will be the device that will...
This is the changelog of build 2 of the 4.0 release. Here is a list of the fixes:
General Changes​
  • Fixed Clear log button not styled.
  • Fixed double clicking change buttons visuals action silently crashing
  • Fixed on discovery message not setting ip correctly.
  • Fixed multiline paste in multiline tagview removing newlines.
  • Fixed removing plugin not removing granted permission
  • Fixed plugin actions not loaded when OK is chosen.
  • Fixed crash for using...
