Streaming With 2 GPU
SeinenV
Hi, first of all, I apologize for my English; I'm using a translator.
I'm planning to use two GPUs, one for streaming and one for gaming. I usually use Warudo because I'm a Vtuber.
This is my hardware:
MB: PRIME B760M-A D4
CPU: i5-14400
GPU: RTX 3060 12GB
RAM: 32 GB DDR4
PSU: 750W 80+ GOLD
The idea is to use a GTX 1650 4GB that I have lying around unused, and have it handle the OBS stream and the avatar program I use, while the gaming would be handled solely by the RTX 3060. Is it worth trying? It's an idea I had, and I did some research, but the videos in my language aren't very technical and the explanations are vague.
Thanks in advance, and please excuse my ignorance.
Terrible idea. OBS runs best with just a single GPU. Your 3060 can encode up to (12) concurrent encodes. Plus, your CPU has an iGPU that can be used to encode additional streams. I do it all the time with my 12900k....
I'll help you with set-up but I need you to post a log after you encode something. Open OBS, run your test & then close/re-open OBS & post the previous log. There's a pinned post at the top of the Windows Support thread that will help you with posting the log.
