spectralizer
spectralizer v1.3.4
That's not really what the plugin is intended for. You can crop the source though and just leave it at three bins
Ok, I understand. Nevertheless this seems to be a bug.
Could you recommend another, better plugin that visualizes the audio in the program output?
#ask
I can't install spectralizer in OBS 21.1.2, this plugin is not showing at obs "add "source menu. Please help me \>o</
#ask
Why are you using an almost four year old version of obs? Spectralizer requires at least 24.0.0 but you should always use the latest.
Clarifying question: Does this run on Mac?
- The overview page only lists Win and Linux
- The download page has .macos.pkg files
- I installed it, but I can't find it in OBS anywhere
<insert confused emoji>
Did you read the first page of the installer?
Hey, i just installed this plugin excactly like shown in the video but it isnt showing up on my Add Sources list. My OBS version is 27.2.3 and im using StreamElements.
Just a heads up, I saw that Waveform added a radial mode and rounded corners which basically means that spectralizer is deprecated so there most likely won't be any updates anymore.
please don't, i'd like more the way spectralizer responses to the audio, and the option to use filters like monstercat, always is a good idea to have choices
The plugin won't disappear, I just won't work on it anymore (I technically haven't for quite a bit already). I might make a pull request to add the monstercat filter to Waveform depending on how easy it is.
How to make Spectralizer works on M1 (Apple Silicon)?
1) Download the latest version of Spectralizer
2) Install Homebrew (https://brew.sh) UNDER Rosetta
  • Right click on TERMINAL App / Get Info
  • Check "Open using Rosetta"
  • Insert the "arch -x86_64" before the installation command from the https://brew.sh like this:
    arch -x86_64 /bin/bash -c "$(curl -fsSL https://raw.githubusercontent.com/Homebrew/install/HEAD/install.sh)"
  • Follow the instructions in the Terminal
3) Install FFTW in the same window of Terminal: brew install fftw
4) Install Spectralizer
5) You are ready to go ;-)
I hope these instructions have helped you!
Thank you bro - THAT did help in the end after brew & fftw uninstall and reinstall.
now I managed to get it running. appreciated.
Has anyone of you gotten Spectralizer to work with M1 ARM optimised OBS build ? My build is 27.2.0, but cannot find the plugin for Spectralizer in the view. For the Rosetta version (26.1.3) the plugin can be seen in the menu. Thanks for any help!
Hi, I did my best, i couldn't installed the Spectralizer on Mac M1. I need help. Any video tutorial didn't worked for me.
Didn't work for me. I installed the Homebrew without problem but when i am going installed the FFTW. it say i can't. Look the image, I don't know what that mean.
I still have problems with it. If the source is coming form an audio file: it's ok. It works fine.
If the source is coming from ASIO source (on my case: microphone connected to the audio interface) it doesn't work
