Source Record
Source Record 0.4.8
hi
its crashed after using nvidia nvenc H.264 but orginal record from ops works good
but the plugin works only if i choose x264 or softwarex264 and thats use my cpu :( any help?
EDIT : as i can see now the nvenc h.264 as i mentioned above it works only on display capture
but wont work on camera (elgato)
AND : if i end task this programe files can work with no issue obs-ffmpeg-mux
hi
Ok i delete source record plugin thin i Uninstall 3.3
then i downloaded older one 0.3.2
all works good as i can see for now
Hi Exeldro, thank you for this update!
Could you add more details on how one can use obs-websocket vendor requests in bitfocus companion for instance?
  • Vendor Name : source-record
  • Request Type : record_start
But it doesn't work.
Please @Exeldro if you have some time, could you help?
Thank you in advance
The vendor request should be like this:
JSON:
 "requestType": "CallVendorRequest",
 "requestData": {
    "vendorName": "source-record",
    "requestType": "record_start",
    "requestData": {
      "source": "Video Capture Device",
      "filter": "Source Record",
      "max_seconds": 50,
      "filename": "test5"
all things in the second requestData are optional
check the response you get for any error message like,'source not found', 'no source found', 'filter not found', 'failed to find filter' or 'filter is not source record filter'
@Exeldro For the moment, I tried 4-5 times and it doesn't crash any longer. thank you.
In case it does again, i will be back with the log.
Thank you for your rapidity
@Exeldro
Thank you so much for the 0.3.4 update!
It mostly fixed the "Stopping Recording..." Issue on OBS 30.1.2.
I did notice one other minor issue which may or may not affect others using this plugin.
If I enable the "Different Audio" option within this plugin, and select anything other than "None" for the "Audio Track" with a valid "source" selected as well, then the "Stopping Recording..." issue returns. This happens regardless of which "Encoder" I selected for the plugin.
I've only tested this scenario under an OBS installed from OBS's Repo package. I'll test this out under a Flatpak install and report back here as soon as I can get to it.
SS
Correct me if I am wrong. If I select an audio track (track 3 for example) and choose a source (SRT for example), I should only pickup audio track 3 played from my SRT sourece.
I ran a test and it is recording every sources with audio playing under track 3
@Exeldro
Hi again
ok now i have some problem or there is somthing wrong i did
first how i use to record, now am using obs (orginal record) to record game + my cam )
and i only add filter to (cam) as source record, to get a file with cam only
so i have 2 files now 1- game + cam + mic + overlay) with no problem dealy
second file cam only without any sound option (delay with cam)
the problem is the cam file there is delay or forward a bit not sync with my mic like the original record
take a look to attached pic plz
why am using sourcs record only on cam? cuz i really dont want that i only need source record for my webcam so how can i fix that
ik the solution to put mic with source record as a track to my webcam but i need to sync it manually and auto sync in adobe not working for some reason
Is there any way to (or plans to) allow Source Record to use a different audio format, specifically a lossless format like FLAC or PCM?
For lossless audio, the current system seems to require doing 2 recordings, one for Source Record and another from OBS, then remuxing the audio from the OBS recording to the video from Source Record. This is pretty annoying because the recordings aren't exactly matched up, so the audio has to be shifted first.
Even an option to just use the local recording audio format as opposed to the stream format would be great.
Exeldro: The latest version of Source Record still doesn't fix OBS v30.1.x hanging when one tries to stop recording (MacOS ARM). The latest plugin works fine if I downgrade to OBS 30.0.2.
To test, just enable source record on one or more sources/scenes. Start recording. Try to stop recording. It will say "Stopping recording..." forever until force quit.
Hmm... weird. I tried on another MacOS system with the latest plugin and OBS v30.1.2 and it works... I have to see if I can reproduce on the problem system with a simpler setup...
That would be great, because I tried it on a colleague's Macbook and it doesn't work on his Macbook either.
