Free Snaz [Deleted]
Status
Not open for further replies.
The album name and album art is not coming from the mp3 tags at all it is pulled from an external database. You just have to make sure the name of the artist and song is correct.
That's just the thing they are correct. So I'm more curious about this database ignoring album info or tagging incorrect album art. One of the album art pointed to a random soundtrack, another pointed at a tribute album of the artist and not the artist's actual album.
Thanks for the response though.
Bare in mind that a song can be in more then one album.
The external database is spotify's so make sure you find it there
hi.i am using obs studio to livestream a football game.my problem is that the snaz, after 59:59 its change (normaly) to1:00:00 and i need my chrono up to go to 90:00.its there a posibility to do that?
Yachak updated Snaz with a new update entry:
Version 1.12.3.0
=== Version 1.12.3.0
+ Added new mediaplayer to Playing Now: iTunes (issue #50)
+ Added new mediaplayer to Playing Now: VLC media player (issue #84)
+ Added option to automaticly start Chrono Up when Chrono Down ends
(issue #97)
+ Playing Now also supports Json file output e.g. for html overlays
(The file can be found in the Data folder > track-info.json)(issue #65)
+ Chrono Up will now let you show total minutes (usage: $totalminutes)
(issue #73)
+ Added option to hide notification...
I have a Problem with my Microsoft .NET Framework.
Everytime i want to start SNAZ it says this: (see Picture)
I'm using Win 10 btw.
Already tried to reinstall -Net framework but i cant find it in settings D:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Configuration.ConfigurationErrorsException: '.', hexadecimal value 0x00, is an invalid character. Line 15, position 1. (C:\Users\antonhall.antonhall-PC\AppData\Local\JimsApps\Snaz.exe_Url_dbamatfk4dvaz3ykr4crkwlnzkz0kr4g\1.12.2.1\user.config line 15) ---> System.Xml.XmlException: '.', hexadecimal value 0x00, is an invalid character. Line 15, position 1.
at System.Xml.XmlTextReaderImpl.Throw(Exception e)
at System.Xml.XmlTextReaderImpl.Throw(String res, String[] args)
at System.Xml.XmlTextReaderImpl.ParseText(Int32& startPos, Int32& endPos, Int32& outOrChars)
at System.Xml.XmlTextReaderImpl.ParseText()
at System.Xml.XmlTextReaderImpl.ParseElementContent()
at System.Xml.XmlTextReaderImpl.Read()
at System.Xml.XmlTextReader.Read()
at System.Xml.XmlTextReaderImpl.Skip()
at System.Xml.XmlTextReader.Skip()
at System.Configuration.XmlUtil.StrictSkipToNextElement(ExceptionAction action)
at System.Configuration.BaseConfigurationRecord.ScanSectionsRecursive(XmlUtil xmlUtil, String parentConfigKey, Boolean inLocation, String locationSubPath, OverrideModeSetting overrideMode, Boolean skipInChildApps)
at System.Configuration.BaseConfigurationRecord.ScanSections(XmlUtil xmlUtil)
at System.Configuration.BaseConfigurationRecord.InitConfigFromFile()
--- End of inner exception stack trace ---
at System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal)
at System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors)
at System.Configuration.Configuration..ctor(String locationSubPath, Type typeConfigHost, Object[] hostInitConfigurationParams)
at System.Configuration.ClientConfigurationHost.OpenExeConfiguration(ConfigurationFileMap fileMap, Boolean isMachine, ConfigurationUserLevel userLevel, String exePath)
at System.Configuration.ConfigurationManager.OpenExeConfigurationImpl(ConfigurationFileMap fileMap, Boolean isMachine, ConfigurationUserLevel userLevel, String exePath, Boolean preLoad)
at System.Configuration.ClientSettingsStore.ReadSettingsFromFile(String configFileName, String sectionName, Boolean isUserScoped)
at System.Configuration.LocalFileSettingsProvider.GetSettingValuesFromFile(String configFileName, String sectionName, Boolean userScoped, SettingsPropertyCollection properties)
at System.Configuration.LocalFileSettingsProvider.Upgrade(SettingsContext context, SettingsPropertyCollection properties, Boolean isRoaming)
at System.Configuration.LocalFileSettingsProvider.Upgrade(SettingsContext context, SettingsPropertyCollection properties)
at System.Configuration.ApplicationSettingsBase.Upgrade()
at Snaz.Forms.MainForm.cg(Object A_0, EventArgs A_1)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1586.0 built by: NETFXREL2
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Snaz
Assembly Version: 1.12.3.1
Win32 Version: 1.12.3.1
CodeBase: file:///C:/Program%20Files%20(x86)/Snaz/Snaz.exe
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
SpotifyAPI
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Snaz/SpotifyAPI.DLL
Newtonsoft.Json
Assembly Version: 8.0.0.0
Win32 Version: 8.0.3.19514
CodeBase: file:///C:/Program%20Files%20(x86)/Snaz/Newtonsoft.Json.DLL
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Windows.Forms.resources
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms.resources/v4.0_4.0.0.0_de_b77a5c561934e089/System.Windows.Forms.resources.dll
AutoUpdater.NET
Assembly Version: 1.2.0.0
Win32 Version: 1.2.0.0
CodeBase: file:///C:/Program%20Files%20(x86)/Snaz/AutoUpdater.NET.DLL
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Kind Regards
Anton
1.12.4.0
=== Version 1.12.4.0
+ Added settings panel for Playing Now (File > Settings > Playing Now)
+ Added option to truncate trackinfo arist, song and/or album (issue #102)
+ Added option to create seperate .txt files for each parameter artist,
song and album (issue #100)
+ The directory for the Json file output can now be choosen (issue #103)
+ Connection improvement for iTunes
+ Fixed bug with foobar2000 with no media playing text
appearance (issue #108)
* Textfiles are now written...
1.12.5.0
Configurable global hotkeys are here !
=== Version 1.12.5.0
+ Added support for configurable global hotkeys (issue #31)
(File > Settings > Hotkeys)
+ Added support for hotkeys to increase and decrease chrono down and
chrono up by specified minutes (File > Settings > Hotkeys)
* Moved option to enable hotkeys to the new Hotkey settings section
(Previously in General section)
+ Added DST (Daylight Saving Time) support for Countdown
+ Fixed: CountDown, issue when both startup options in...
Hello, I love the program, but I do have an issue. Minor issue, but when playing music, the text display will sometimes not work. I usually have to either restart snaz or pause, then play to fix. Not sure if bug, or just my comp being....my comp. Any feedback would be awesome.
Status
