Unhandled exception: 80000003
Date/Time: 2026-06-15, 16:26:33
Fault address: 7FF88797F2E0 (d:\obs\obs-studio\obs-plugins\64bit\libcef.dll) <------Here
libobs version: 32.1.2 (64-bit)
Windows version: 10.0 build 26200 (release: 25H2; revision: 8655; 64-bit)
CPU: AMD Ryzen 7 5700X3D 8-Core Processor
Thread 6AD8: CrBrowserMain (Crashed) <------Here
The top of logs point to a Browser Source. Might want to check through your overlays you have setup.
Thank you for both your help, it seems the problem was Aitum that wasn't up to date, dunno why but i did not notice itThe crash looks like happening somewhere in a custom dock of the Aitum Stream Suit third party plugin. It could be an issue that happened once or a recurrent problem. You should consult its dev about this crash and make sure you have the latest update and if it's compatible with the OBS version you're using.
