Bug Report OBS Window Capture Not Working
AnubisCOD
Prior to today, Window Capture WAS working just fine. Now it's just a black empty box. I have even attempted to capture by sub region and that doesn't capture anything as well. Is there some kind of update or something wrong with OBS? I am noticing that there seems to be many issues as of late going on with OBS. An immediate response would be helpful!
[12:07:17: CLR host plugin strings not found, dynamically loading 4 strings
12:07:17: CLRHost::Initialize() attempting to load and start the .NET runtime (null)
12:07:17: CLRHost::Initialize() Found version v2.0.50727 .NET runtime
12:07:17: CLRHost::Initialize() Found version v4.0.30319 .NET runtime
12:07:17: CLRHost::Initialize() attempting to use v4.0.30319 .NET runtime
12:07:17: CLRHost::LoadInteropLibrary() load the assembly plugins\CLRHostPlugin\CLRHost.Interop.dll
12:07:17: CLRHost::LoadPlugins() attempting to load the plugin assembly CLRBrowserSourcePlugin
12:07:18: CLRHost:: Could not find/load browser settings at location C:\Users\Emilio\AppData\Roaming\OBS\pluginData\browser.json
12:07:18: CLRHost:: Exception: System.IO.FileNotFoundException: Could not find file 'C:\Users\Emilio\AppData\Roaming\OBS\pluginData\browser.json'.
12:07:18: File name: 'C:\Users\Emilio\AppData\Roaming\OBS\pluginData\browser.json'
12:07:18: at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
12:07:18: at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
12:07:18: at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
12:07:18: at CLRBrowserSourcePlugin.Shared.BrowserSettings.Reload()
12:07:18: CLRHost::LoadPlugins() successfully added CLR plugin [Type: CLRBrowserSourcePlugin.CLRBrowserSourcePlugin, Name: CLR Browser Source Plugin]
12:07:22: Open Broadcaster Software v0.657b - 32bit (´・ω・`)
12:07:22: -------------------------------
12:07:22: CPU Name: Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
12:07:22: CPU Speed: 3400MHz
12:07:22: Physical Memory: 4095MB Total, 4095MB Free
12:07:22: stepping id: 3, model 60, family 6, type 0, extmodel 1, extfamily 0, HTT 1, logical cores 8, total cores 4
12:07:22: monitor 1: pos={0, 0}, size={1920, 1080}
12:07:22: Windows Version: 10.0 Build 10586 (revision 0)
12:07:22: Aero is Enabled
12:07:22: OBS Modules:
12:07:22: Base Address Module
12:07:22: 00360000 OBS.exe
12:07:22: 64530000 OBSApi.dll
12:07:22: 67580000 CLRHostPlugin.dll
12:07:22: 65DF0000 DShowPlugin.dll
12:07:22: 65DC0000 GraphicsCapture.dll
12:07:22: 638F0000 NoiseGate.dll
12:07:22: 731E0000 PSVPlugin.dll
12:07:22: 67560000 scenesw.dll
12:07:22: ------------------------------------------
12:07:22: Adapter 1
12:07:22: Video Adapter: NVIDIA GeForce GTX 660
12:07:22: Video Adapter Dedicated Video Memory: 1552744448
12:07:22: Video Adapter Shared System Memory: 2742157312
12:07:22: Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
12:07:22: Adapter 2
12:07:22: Video Adapter: Intel(R) HD Graphics 4600
12:07:22: Video Adapter Dedicated Video Memory: 117964800
12:07:22: Video Adapter Shared System Memory: 4176936960
12:07:22: =====Stream Start: 2016-05-12, 12:07:22===============================================
12:07:22: Multithreaded optimizations: On
12:07:22: Base resolution: 1280x720
12:07:22: Output resolution: 1280x720
12:07:22: Loading up D3D10 on NVIDIA GeForce GTX 660 (Adapter 1)...
12:07:22: Audio Format: 48000 Hz
12:07:22: Audio Channels: 2 Ch
12:07:22: Playback device {0.0.0.00000000}.{8f63224c-aebb-493b-8cc1-e6198b07238f}
12:07:22: Using desktop audio input: Speakers (Realtek High Definition Audio)
12:07:22: Global Audio time adjust: 0
12:07:22: Using auxilary audio input: Microphone (Yeti Stereo Microphone)
12:07:22: Mic time offset: 0
12:07:22: Audio Encoding: AAC
12:07:22: bitrate: 128
12:07:22: Using text output
12:07:22: Using bitmap image
12:07:22: Using bitmap image]
