JonesGaming
i am using OBS Studio for livestreaming almost every day the past 6 weeks and i never had any problems with it. But today i had 5 crashes during a 10h livestream and i do not know exactly what could cause those problems.
Today i changed the encoding setting from "very-fast" to "faster" - yes i know that this is a bit heavy but it didn't impact my system and i didn't drop a single frame until OBS crashed. After the second crash i reverted the setting to back "veryfast" but OBS crashed 3 more times with the same setting i used for the past 6 weeks.
I included as many logs from today as possible in hope someone can find something in them....
Windows also logged some informations as Event ID 1000 - Application Error:
Here are some system specs.
AMD Ryzen 7 1800x
16GB RAM
Steinberg Audio Interface UR22 MK2
GTX 1080TI
Windows 10 - 10.0.18362
Thank you very much ;)
Name der fehlerhaften Anwendung: obs64.exe, Version: 24.0.3.0, Zeitstempel: 0x5da1792b
Name des fehlerhaften Moduls: obs-browser.dll, Version: 0.0.0.0, Zeitstempel: 0x5da178e6
Ausnahmecode: 0xc0000409
Fehleroffset: 0x0000000000157821
ID des fehlerhaften Prozesses: 0x7008
Startzeit der fehlerhaften Anwendung: 0x01d5ea77b8bbd7a9
Pfad der fehlerhaften Anwendung: C:\Program Files\streamlabs-obs-studio\bin\64bit\obs64.exe
Pfad des fehlerhaften Moduls: C:\Program Files\streamlabs-obs-studio\obs-plugins\64bit\obs-browser.dll
Berichtskennung: a1cc2496-f972-4d83-8e91-9a4109f37087
Vollständiger Name des fehlerhaften Pakets:
Anwendungs-ID, die relativ zum fehlerhaften Paket ist:
AMD Ryzen 7 1800x
16GB RAM
GTX 1080TI
