OBS Studio Will Not Give Higher Than 720p Source Resolution for Twitch
LaRubric
Hello all, thank you for giving my post the time of day.
I'm in a very frustrating situation. I've made a move from SLOBS to OBS and despite having the exact same settings, as well as following the guidance of several online tutorials and performing bandwith tests, I won't get a source resolution higher than 720p. Up until now I have had 1080p used without any issues whatsoever but the moment I transferred to OBS, I can't get to it anymore. I've screenshotted my settings and attached them so you can peruse them. I've also included a screenshot of my bandwith tests which, for some reason, were not displaying the video resolution or any other stream information like they usually would.
Any help at all would be appreciated. I'd prefer not to have to forsake all the work I put in and go back to SLOBS!
I consulted the OBS Discord for this problem and, fortunately, discovered exactly the issue. I will post here for posterity in case anyone suffers like me.
This setting - this single button - messes with your source resolution. It wasn't divulged in any tutorial or guide, somehow, and it made me feel insane. Disable this and it'll work right as rain. Thank you to Rufus and PowerfulDot from the Discord for their immediate help and expertise!
I moved from windows to linux, having the same settings for obs and I'm able only to stream at 1080 while in Windows I could stream with at least 3 resolutions: 480, 720 and 1080. Enable enhanced broadcasting makes me stream only in 720 resolution, disabling it I can stream in 1080 but no other resolution.
