OBS-RTSPServer 3.1.0
It doesn't work with version 32? which is the latest working OBS version for this? There is any other alternative for RTSP server? Thanks
Which version of the plugin are you using and under which platform? 3.1.0 is the most recent release. The dialog from Tools opens up just fine, though I haven't tried it just yet.
My setup is as follows:
  • Windows 11 Pro
  • OBS Studio 32.0.4
  • RTSP Server 3.0.1 (not the beta).
Hope this helps.
--Katt. =^.^=
I have tried most versions on github, didn't work.
Someone should help me with VCAMpro apk file(the password if required), and the version of OBS and obs-rtspserver that works with it on windows 10.
  • Windows 11 Pro
  • OBS Studio 32.0.4
Hope this helps.
--Katt. =^.^=
i cant find RTSP Server 3.0.1 (not the beta) in the github.
Hey, i have this plugin on my Windows laptop, used to work fine, using MXVR on Android to receive the rtsp stream, however when i tried again recently the rtsp isn't going out at all.
I can see it's streaming on my laptop and am able to access it in VLC, but when i try using vlc on another device (on the same network), there's no stream.
I have added rules for firewall to allow all outgoing from OBS and for those ports etc, but still not able to receive the rtsp on any other device except the one it's running on.
Would appreciate some help!
Managed to sort it out. I was adding outbound firewall rules instead of inbound.
