L LeXiCZ New Member Dec 27, 2015 #1 http://imgur.com/qJsGvFI How else to fix, here's your files. please i need help. Thanks! I using OBS 32 bit. Attachments OBSCrashDump2015-12-27_9.dmp OBSCrashDump2015-12-27_9.dmp 226.1 KB · Views: 61 OBSCrashLog2015-12-27_9.txt OBSCrashLog2015-12-27_9.txt 5.8 KB · Views: 32
R R1CH Forum Admin Developer Dec 28, 2015 #2 Remove the CLR plugin or fix whatever is crashing the .NET framework.
R R1CH Forum Admin Developer Dec 28, 2015 #4 It's part of Windows, you may need to uninstall / reinstall it.
