Bug Report OBS freezing, stream still live, MAJOR ISSUE
BDRMrTBag
The latest OBS update for the classic version has become pretty unstable, its sometimes fine, sometimes it decides to crash, leaving the stream live but I cannot change scenes, click on anything on OBS without it having (Not Responding) come up, I have captured an image showing its frozen completely, it happens randomly for no reason whatsoever, I cannot find a fix, it only started happening after the latest update.
When I try to change scenes, it doesn't respond, its an issue which causes me to have to bring up the task manager just to even get it to close, its annoying and its really having an effect on my streaming, when it has happened, I have to close OBS a number of times just to even upload the log file!
As you can see, I'm still live but the bottom information has disappeared, my viewers could still see everything too
You should switch to OBS Studio. OBS Classic has many issues that won't be fixed anymore. Report back if it works better with OBS Studio.
