OBS audio
Littlelotty25
I have updated OBS and now it can't pick up any audio from voice meter potato. Before the update I was able to use voice meter fine for my audio inputs to separate my game volume from any discord calls I was in and now it just wont pick up anything which has made it hard to stream. My entire system is running via voice meter, it is the default for my computers audio. I have tried everything I can think of, I have tried, making the sure the properties are correct, I have made use OBS isn't muted in my system sound settings. I have watched a few videos but nothing had helped. Has anyone come across this issue and found a fix. So far the only thing I can do to grab the audio is to window capture whatever I am using that has sound and make it detect audio, which is okay for a quick fix but I would like to be able to use voice meter in OBS again.
Thank you everyone's time and support on this
I managed to find a fix for this. It looks like it might have been on voice meter's side which is strange as I've been running voice meter for years and never had to do this, but either way if others have this issue the solution I found was - Open file location for voice meter, then open the app called "Virtual IO Control Panel" then go to the options section and select "enable loopback streaming" after this you will need to restart your computer but it fixed my issues OBS now sees voice meter as an output and the levels were been shown.
