Question / Help OBS and Logitech Webcam
Merci
Recently had to reinstall Windows 10 and now whenever I go to Properties>Configure Video on my webcam I get these generic settings instead of the Logitech ones I used to have. I found a thread from 2018 where someone had the same problem and their solution was to update the Logitech drivers but when I try to look for them they don't seem to exist anymore. Logitech simply directs me to Logitech G-Hub or Logitech Capture. I downloaded both of those apps but they don't do anything for OBS. I also tried to update drivers in Device Manager but it didn't help.
Thank you, that link you provided gives an alternative to download the old software and that seems to work for me :)
It worked for me, when I open obs it gives me the Logitech Advanced options that I was looking for in the second picture I posted. I had another computer that had the same problem and it worked for both of them. Weird but at least it works now :P
Logitech now uses UVC drivers...
I use them with no problem and they allow more than one Logitech cam control at the same time.
Logitech Capture replaces the old software.
Watch this: https://blog.logitech.com/2018/01/03/multi-camera-streaming-with-logitech-webcams-a-how-to-guide/
So this is years later. I had this issue way back when. But sadly now again im having it due to a Windows full reinstall. That link doesn't take you anywhere anymore... please help.
