Bug Report My sizing is off and it has nothing to do with DPI
ryigui
Obs works fine on my computer, the only problem is that everything is tiny. It makes it almost too annoying to use and every time I try to find a solution its always "disable or enable DPI" and I have 100 times and nothing. Here is a picture of what it looks like. I would really appreciate any help.
I'm running on Windows 10, 64-bit.
Also I've run both 64 and 32 bit versions and same thing happens with both.
Update: I have continued to mess with the DPI settings anywhere I can and the problem still persists.
