Music Visualizer?
saors
Does anyone know of a music visualizer that I can overlay on top of my broadcast?
it doesn't really matter what type of visualizer (wave, bars, etc.) but the ability to resize it would be fantastic.
I'm looking for the same thing actually. Found something that does text, but something that had waves, bars, and the like would be awesome.
I just capture Foobar2000's visuallizer and chroma key out the back, you can also get skins which change the colour. here's an example of mine
Can you do the same thing with Winamp? I'm using Snip for the text part which doesn't work with Foobar2000 unfortunately.
Turtlemaw said:
http://obsproject.com/forum/viewtopic.php?t=676
Thanks, I got that to work! The visualizer isn't exactly what I wanted but it'll do for now.
Are there any skins out there for v1.3.1 that have interesting visualizers? All the ones I've found so far say they only work for older versions only (if they have version info at all).
All those are great, but if you are like me and always want best of the best you should really check out VSXU Player http://www.vsxu.com/products/player
It offers more effects although it can be a little tricky getting it to work.. They have a guide on the site, but I found it a bit hard to understand. If anyone needs help pertaining to setting it up feel free to shoot me a PM. Hope this helped and good luck!
Are you familiar with foobar's Shpeck (foo_vis_shpeck)? It runs perfectly well with the latest versions of foobar and allows you to use Winamp's Milkdrop, AVS and Spectrum Analyzer Classic within a foobar screen element.
I use AIMP. Just capture the window setting up the x and y to match the "Visualizer" and I Chroma Key the black. You can get more Visualizations on AIMP website.
