LyricDisplay - Professional Lyrics Overlay for Production/Streaming Software
LyricDisplay - Professional Lyrics Overlay for Production/Streaming Software 6.5.3
peteralaks submitted a new resource:
LyricDisplay - Professional Lyrics Overlay for Production/Streaming Software - Professional lyric display with transparent overlays, dual independent outputs and multiple features
LyricDisplay
Professional real-time lyric display for streaming, church services and other live events
Version: 4.4.0 | Windows 10/11 (64-bit)
What is LyricDisplay?​
LyricDisplay is a free desktop app that provides perfectly clear, sharp and transparent lyric overlays for OBS Studio, VMix or any broadcast/production software that accepts browser input sources.
Ideal for:
- Church worship services
- Live concerts & events
- Karaoke...
peteralaks updated LyricDisplay - Professional Lyrics Overlay for Production/Streaming Software with a new update entry:
v4.8.0
What Changed?
- Added EasyWorship Song Import Wizard for users to migrate saved songs in EasyWorship to loadable .txt files perfectly
- Added two more free online lyric providers to the online lyrics search to enable larger search scope and result base
- Improved online lyric search algorithm and fixed reported bugs
- Added helpful tips and operation instruction modal with description of features
- Refactored Connection Diagnostics display
- Numerous big fixes and performance...
v4.9.0
Critical Fixes:
Fixed white background issue for VMix and Wirecast - also addresses white flashes for OBS. If still noticed, make sure to create issue on main app repo here or contact the developer here.
Other Features:
- Integration Guide for OBS, vMix and Wirecast accessible from Help Menu in app window
- Minor bug fixes and more performance improvements
v5.0.0
LyricDisplay v5 introduces new integrations, interface improvements, and general refinements focused on usability, clarity, and performance.
New Features
- Settings help modal for quick in-app guidance
- Keyboard workflow with new keyboard shortcuts for quick movements
- Redesigned connection diagnostic modal for better clarity
- Collapsible advanced section in the online lyrics search modal
- Welcome splash screen with integration instructions and key information...
v5.2.0
What changed?
  • Updated settings panel to add advanced controls (collapsed by default) to numerous settings
  • Updated lyrics parsing to group suitable lines to display as one on output displays
  • Added lyrics change animation settings
  • Users can decide to ungroup lines directly from the control panel
  • Fixed unstable background height by adding option to set default height
  • Fixed multiple bugs and improved performance
v5.7.0
What changed?
- Added Stage monitor output for stage/operator lyrics view: In addition to Output 1 and 2, the Stage view is a dedicated output channel for operators and worship leaders on stage, providing professional confidence monitoring. Configure stage view from Output Settings Panel to customize current lyric line, upcoming lyric line, send custom messages, show timer, etc. all synchronized with the control panel and output channels. Stage display can be accessed from any...
v5.8.1
LyricDisplay v5.8.1​
Fixed Bugs:
✅ Persistent timestamps from last song when load drafts from mobile
✅ Multiple external displays handling
✅ Version check update not launching from about app modal
Added Features:
✅ Quit app confirmation
✅ Turn off individual display outputs
✅ Save setlist to disk
Numerous other bug fixes and performance improvements
LyricDisplay v5.9.0
What changed?
Bug Fixes
- Fixed a bug where autosave settings weren't being saved after closing the modal
- Fixed and improved video background streaming over multi-PC setup on LAN
- Fixed the bold emphasis not applying on grouped/translation lines
- Multiple minor bug fixes and issues
New Features
- User's system/installed fonts now show up on font tray and can be used for outputs
- Performance improvements
LyricDisplay 5.9.4
Bug Fixes:
- Fixed issue where horizontal padding was not working if background band opacity is less than 1
- Fixed bold not applying on grouped/translation lines
- Fixed app window not syncing properly with persisted dark mode state
- Host of minor bug fixes and issues.
New:
- Increased maximum setlist files to 50
- Added new modern colour picker to replace browser default colour picker
- Added keyboard control for font select overlay (Up/Down direction keys for...
LyricDisplay 5.9.12
Bug Fixes/Changes:
- Fixed issue with stale/old timestamps on mobile controllers
- Fixed issue where splitting groups on mobile controllers didn't sync with desktop's list
- Updated multiple UI elements to properly display consistent tooltips
- Updated templates and new lyrics file icon to be more user-identifiable (from @psyirius)
New Features:
- Updated lyrics list to include section markers for structured lyric files
- Updated parser to identify markers and group...
LyricDisplay 5.10.0
Bug Fixes:
- Fixed timestamp parsing to intelligently prevent translation grouping for lines starting with timestamps
- Added optional always on background switch so turning off output toggle doesn't automatically keep media background visible in full screen mode
- Improved save guard logic in song canvas to avoid redundant renders
- Fixed advanced settings for max lines not collapsing issue
- Fixed issue where some input fields on settings panel could have empty values
- Fixed...
LyricDisplay 5.10.4
Bug Fixes:
- Fixed scroll reset bug after ungrouping grouped list items on lyrics list
- Fixed ungroup bug not propagating to desktop from mobile controller
- Multiple minor reported bug fixes
New Features:
- Added new context menu for lyrics list including multiple items
- Minor UI tweaks to enhance your LyricDisplay experience
LyricDisplay 5.10.8
Bug Fixes:
- Fixed max lines calculator bug not disabling font input field in settings panel and wrongly calculating lines
- Fixed the new song save bug that showed overwrite file modal even when creating new song
- Fixed undo bug that cleared canvas content in edit mode
- Increased backend start timeout to help slower systems spin up before declaring dead
Additions:
- Keyboard shortcuts for lyrics list and control panel operations (all documented in keyboard shortcuts...
LyricDisplay 6.0.0 New Year Update
New Features:
- New top menu bar replacing native default for a more polished, modern outlook
- New load into canvas feature that lets users load a .txt or .lrc file into the canvas editor when needed
- Dark mode toggle and preferences (coming soon) button added to top bar of left side of control panel interface
Bug Fixes:
- Fixed section tags parsing bug that didn't detect some section formats
- Fixed auto scroll bug in full screen mode advanced section
- Fixed static...
LyricDisplay 6.1.0
Bug Fixes:
- Fixed double output templates modal scrollbar
- Fixed bug where file path metadata was lost for files added to/loaded from setlists
Added Features:
- Exporting setlist as PDF/TXT Document: Users can now export setlists to documents that can either contain full lyrics of each song on the list or just titles.
- Enhanced Preview Outputs Modal to better represent lyrics preview on screen with multi-resolution controls.
- Improved handling for file drag into...
