Issues in Sting Transition
つむぎ
I'm Japanese, so I apologize if my English is strange.
On my computer, setting the Stinger transition causes two problems.
First, the music for a specific scene keeps playing continuously. It stops only after playing to the very end.
Second, that specific scene will always be displayed at the start of the transition.
Closing the app or similar actions will transition to a different scene.
I deleted all files, uninstalled the app, reset the OBS, and updated my Mac, but it still doesn't work.
Does anyone know a solution? If it's a bug, could you please fix it and provide a new version?
I know you can select crossfade as an option which should crossfade the audio of your current scene into the next scene you're moving to (for me when I monitor this, I don't think it works) but that's meant to be the solution for the audio issue you are having.
Thank you for responding to my comment. I was worried no one would answer.
However, I already tried crossfading, but it didn't work. Nothing changed at all.
I've had a similar issue with it, I think it works on Windows, but not on the Mac - but that's the only option I see to at least address the audio issue within the transition (so maybe it'll get fixed for Mac soon?)
