Input Overlay
Input Overlay v5.0.5
Does Input History no longer exist? It was quite useful for recording tutorials, but I'm not finding it in this latest version of Input Overlay.
My default screen:
İnput overlay screen:
I need input overlay config
Up: W
Down: S
Right: D
Left: A
Start: Enter
Select: Shift
Atack: Num 1 (number keys on the right)
Jump: Num 2 (number keys on the right)
I set the direction keys from the page you provided, but it gave the output as json. How can I make a json file with ini extension?
You don't the newest version uses json instead of ini
I downloaded version 5.0.0-rc1 and the problem is solved. Thank you.
I made a Turk translation for Input Overlay v5.0.0-rc1
Translators:
-Tarkan ULUTÜRK (Turk)
I would appreciate if you add my name to the translators section.
the Dual Shock 4 option doesn't work for me. I connected the controller with a USB cable to my PC.
the 360 one works without any issues for me.
I'm using version 4.7.4b, cause for the pre release of version 5 there is no JSON preset for any of the controllers.
in general, for the config creation tool, it would be helpful to know how far the active/switched versions of the same button need to be placed in the image. I found out its 3 pixels.
also, it's a bit annoying to adjust one single image over and over, especially to test stuff.
It would be much better if you could create import little images of the buttons
The information about creating the texture is here. Using multiple textures would also overcomplicate the whole process, the idea is that you create the texture beforehand and then create the overlay config.
Latest versions of OBS and this plugin. After copying files and opening OBS - mouse and keyboard almost stopped working until OBS was closed (via Task Manager).
Has anybody created a full qwerty keyboard with configuration in the new format (json)? It wasn't included in the presets for 5.0.0. I'm looking for qwerty, F buttons not necessary, preferably with arrow keys. I'm trying to make some videos to teach typing.
