Bug Report If you get red output from a device, read here
Status
Not open for further replies.
I just tried to use the 32-bit version of OBS but it unfortunately still give me a red screen. Is there any other way around this? Is there perhaps a way I can switch my 64-bit OS to 32-bit temporarily when I'm streaming?
Here some steps for you AverMedia LGP guys (maybe also for other users). Hope it'll fix it:
1. LGP Streaming Software needs to be running
2. Close your Browser (I know that if Chrome is running it makes some troubles with OBS and the detection of the Capture Device). Make also sure that you closed chrome completely, the program isn't closed if you only close the window.
(After your stream is set up you can open the Browser again)
Should be something like this:
2. Start OBS 32 Bit (The 32 Bit Version is in the main directory, the 64 bit version is in the "64bit"-folder
("C:\Program Files (x86)\OBS", if you not changed the directory.)
Better make a shortcut of the 32 bit version, usually you don't need the 64 bit version anyway.
3. Source -> Videodevices -> LGP Stream Engine (C875 Capture is NOT the right Capture Device)
If not installed, get it here. Make sure you select the right language in the upper right corner of the website!
Post your feedback please if possible!
Hi all. Been having issues with my XCapture-1 device. I got it to finally be recognized in OBS but now I'm getting a red screen.
Hope I'm posting these right.
Device: CY3014 USB, Analog 01 Capture
  Pin: Video Capture
    category: PIN_CATEGORY_CAPTURE
    00.) major type: MEDIATYPE_Video
         sub type: MEDIASUBTYPE_YUY2
         format type: FORMAT_VideoInfo (YUY2)
    01.) major type: MEDIATYPE_Video
    02.) major type: MEDIATYPE_Video
    03.) major type: MEDIATYPE_Video
    04.) major type: MEDIATYPE_Video
    05.) major type: MEDIATYPE_Video
    06.) major type: MEDIATYPE_Video
    07.) major type: MEDIATYPE_Video
    08.) major type: MEDIATYPE_Video
    09.) major type: MEDIATYPE_Video
    10.) major type: MEDIATYPE_Video
    11.) major type: MEDIATYPE_Video
    12.) major type: MEDIATYPE_Video
    13.) major type: MEDIATYPE_Video
    14.) major type: MEDIATYPE_Video
    15.) major type: MEDIATYPE_Video
    16.) major type: MEDIATYPE_Video
    17.) major type: MEDIATYPE_Video
    18.) major type: MEDIATYPE_Video
    19.) major type: MEDIATYPE_Video
    20.) major type: MEDIATYPE_Video
    21.) major type: MEDIATYPE_Video
    22.) major type: MEDIATYPE_Video
    23.) major type: MEDIATYPE_Video
    24.) major type: MEDIATYPE_Video
    25.) major type: MEDIATYPE_Video
    26.) major type: MEDIATYPE_Video
    27.) major type: MEDIATYPE_Video
    28.) major type: MEDIATYPE_Video
    29.) major type: MEDIATYPE_Video
    30.) major type: MEDIATYPE_Video
    31.) major type: MEDIATYPE_Video
    32.) major type: MEDIATYPE_Video
    33.) major type: MEDIATYPE_Video
    34.) major type: MEDIATYPE_Video
    35.) major type: MEDIATYPE_Video
    36.) major type: MEDIATYPE_Video
    37.) major type: MEDIATYPE_Video
    38.) major type: MEDIATYPE_Video
    39.) major type: MEDIATYPE_Video
    40.) major type: MEDIATYPE_Video
    41.) major type: MEDIATYPE_Video
    42.) major type: MEDIATYPE_Video
    43.) major type: MEDIATYPE_Video
    44.) major type: MEDIATYPE_Video
    45.) major type: MEDIATYPE_Video
    46.) major type: MEDIATYPE_Video
    47.) major type: MEDIATYPE_Video
    48.) major type: MEDIATYPE_Video
    49.) major type: MEDIATYPE_Video
    50.) major type: MEDIATYPE_Video
    51.) major type: MEDIATYPE_Video
         format type: FORMAT_VideoInfo (YUY2)]
It was getting long so I'm posting the upload for my Log file
https://gist.github.com/552986a919392a894f58
Any help would be greatly appreciated.
I'm using AverMedia C874
Device: AVerMedia USB HD Capture
Pin: Stream Out
00.) major type: MEDIATYPE_Stream
sub type: {E06D8023-DB46-11CF-B4-D1-00-80-5F-6C-BB-EA}
format type: FORMAT_None
Pin: Virtual Stream Out
Device: BCC950 ConferenceCam
Pin: Capture
format type: FORMAT_VideoInfo2
sub type: MEDIASUBTYPE_H264
format type: FORMAT_VideoInfo (H264)
sub type: MEDIASUBTYPE_MJPG
format type: FORMAT_VideoInfo (MJPG)
52.) major type: MEDIATYPE_Video
53.) major type: MEDIATYPE_Video
I am having issues with 3 images I added.
Device: Lenovo EasyCamera
Pin: Capture
Pin: Still
category: PIN_CATEGORY_STILL
Device: AVerMedia C835 Capture
Pin: Virtual Video Out
category: {494B594A-026C-48A3-9A-8A-EC-C3-5C-FE-33-20}
sub type: {C5C928BE-6F6D-42B6-B6-E0-43-B5-62-D9-73-C1}
Pin: VBI
category: PIN_CATEGORY_VBI
Pin: PCM Out
Device: XSplitBroadcaster
Pin: Output
sub type: MEDIASUBTYPE_NV12
format type: FORMAT_VideoInfo (NV12)
sub type: MEDIASUBTYPE_AYUV
format type: FORMAT_VideoInfo (AYUV)
sub type: MEDIASUBTYPE_RGB32
format type: FORMAT_VideoInfo (00000000)
sub type: MEDIASUBTYPE_RGB24
My webcam is either isn't showing up or it has a red screen whenever I try it out on OBS
Device: Logitech HD Pro Webcam C920
Pin: Capture
I have a file of my previous log if that help.
Pin: VBI
Pin: PCM Out
Device: LGPLite Stream Engine
Pin: VBI
Pin: PCM Out
I don't get a red screen... it just doesn't display anything...
Closed google chrome, no skype opened and Stream Engine Configuration page opened... Help :'(
Device: A4 TECH PC Camera H
Pin: Запись
sub type: MEDIASUBTYPE_I420
format type: FORMAT_VideoInfo (I420)
Device: Sony HVR-V1E
  Pin: MPEG2TS Out
  sub type: {138AA9A4-1EE2-4C5B-98-8E-19-AB-FD-BC-8A-11}
  format type: {97E218B1-1E5A-498E-A9-54-F9-62-CF-D9-8C-DE}
  01.) major type: MEDIATYPE_Stream
I've tried lots of different ways to no avail any help would be fantastic.
Log: https://gist.github.com/683c69db0dd8d6c616e6
Sometimes it works sometimes it doesn't (it's the USB one that's causing the problems) I don't know what to do anymore, if I use video capture device I get it to work 1/200 but if I use window capture mode to capture the window of the software I got the capture card with it doesn't work (it worked on my previous computer like that) [attached image shows my settings for the capture card which I don't change when it sometimes works and sometimes doesn't]
Pin: Capture
Pin: Still
Device: ManyCam Virtual Webcam
Pin: Capture
Device: USB 2861 Device
Pin: Capture
I'm using a hauppauge hd pvr 2... and... these are the results i got...
Device: Hauppauge Siena Video Capture
Pin: 656
category: {4EF89945-4D43-48D7-A4-42-A1-B4-E7-81-30-36}
sub type: {32574348-005B-4504-99-F8-90-82-6C-80-66-57}
format type: FORMAT_VideoInfo (CXF2)
Device: Integrated Webcam
Pin: Capture
Device: FFsource
Pin: FFsource
Pin: Output
My problem is with the AverMedia
I tried using the LGP Stream Engine but I still have the red screen. I'm using the 32-bit version of OBS.
Also when ever I try to open the Stream Engine it says no device detected even though I have the device plugged into my laptop.
http://imgur.com/2wgFCHJ
Device: CyberLink Webcam Splitter
Pin: Capture
Pin: VBI
Pin: PCM Out
Device: LGP Stream Engine
Device: VDP Source
Pin: Virtual Cam
sub type: {33363248-0000-0010-80-00-00-AA-00-38-9B-71}
format type: FORMAT_VideoInfo (H263)
Hello, I have some problems with Live Stream Youtube. Bitstream is very low with OBS. I have a Red signal..how can I get the grreen signal? When I connected just few seconds it s green, but then It stop in 1776kbs and it s a red signal....what happen?
thanks!
Pat
00:03:10: Open Broadcaster Software v0.656b - 64bit ( ^ω^)
00:03:10: -------------------------------
00:03:10: CPU Name: AMD FX(tm)-8350 Eight-Core Processor
00:03:10: CPU Speed: 4013MHz
00:03:10: Physical Memory:  16283MB Total, 14209MB Free
00:03:10: stepping id: 0, model 2, family 21, type 0, extmodel 0, extfamily 3, HTT 1, logical cores 8, total cores 4
00:03:10: monitor 1: pos={0, 0}, size={1920, 1080}
00:03:10: monitor 2: pos={1920, 0}, size={1920, 1200}
00:03:10: Windows Version: 6.3 Build 9600 (revision 17415)
00:03:10: Aero is Enabled
00:03:10: OBS Modules:
00:03:10: Base Address     Module
00:03:10: 000000001C9A0000 OBS.exe
00:03:10: 0000000015570000 OBSApi.dll
00:03:10: 0000000021D50000 DShowPlugin.dll
00:03:10: 00000000242B0000 GraphicsCapture.dll
00:03:10: 0000000024100000 LogiLCD.dll
00:03:10: 0000000022870000 NoiseGate.dll
00:03:10: 000000001DAC0000 PSVPlugin.dll
00:03:10: 000000001DA90000 scenesw.dll
00:03:10: ------------------------------------------
00:03:10: Adapter 1
00:03:10:   Video Adapter: NVIDIA GeForce GTX 960
00:03:10:   Video Adapter Dedicated Video Memory: 2062217216
00:03:10:   Video Adapter Shared System Memory: 2147807232
00:03:10:   Video Adapter Output 1: pos={0, 0}, size={1920, 1080}, attached=true
00:03:10:   Video Adapter Output 2: pos={1920, 0}, size={1920, 1200}, attached=true
00:03:10: =====Stream Start: 2015-10-11, 00:03:10===============================================
00:03:10:   Multithreaded optimizations: On
00:03:10:   Base resolution: 1920x1080
00:03:10:   Output resolution: 1920x1080
00:03:10: Loading up D3D10 on NVIDIA GeForce GTX 960 (Adapter 1)...
00:03:10: Audio Format: 48000 Hz
00:03:10: Audio Channels: 2 Ch
00:03:10: Playback device {0.0.0.00000000}.{8975eeb9-2b01-4e83-888f-20fa8ffeb92f}
00:03:10: Using desktop audio input: Altavoces (Sound Blaster Z)
00:03:10: Global Audio time adjust: 0
00:03:10: Using 5.1 speaker setup
00:03:10: Using auxilary audio input: Micrófono (iO|2)
00:03:10: Mic time offset: 0
00:03:10: Audio Encoding: AAC
00:03:10:     bitrate: 192
00:03:10: Using text output
00:03:10:     device: SparkoCam Video Source,
00:03:10:     device id \\?\root#image#0000#{65e8773d-8f56-11d0-a3b9-00a0c9223196}\global,
00:03:10:     chosen type: RGB24, usingFourCC: false, res: 1920x1080 - 1920x1080, frameIntervals: 333333-640000000
00:03:10:     use buffering: false - 0, fourCC: 00000000
00:03:10:     audio device: Desactivar,
00:03:10:     audio device id Disabled,
00:03:10:     audio time offset 0,
00:03:10:
00:03:11: Using directshow input
00:03:11: Using Slide Show
00:03:11: Scene buffering time set to 700
00:03:11: ------------------------------------------
00:03:11: Video Encoding: x264
00:03:11:     fps: 30
00:03:11:     width: 1920, height: 1080
00:03:11:     preset: veryfast
00:03:11:     profile: high
00:03:11:     keyint: 120
00:03:11:     CBR: yes
00:03:11:     CFR: yes
00:03:11:     max bitrate: 5000
00:03:11:     buffer size: 5000
00:03:13: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:03:13:   New Scene
00:03:14: Using bitmap image
00:03:14: Using text output
00:03:25: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:03:25:   New Scene
00:03:25: Using text output
00:03:25: Using Slide Show
00:03:27: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:03:27:   New Scene
00:03:27: Using text output
00:03:27: Using bitmap image
00:05:38: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:05:38:   New Scene
00:05:39: Using bitmap image
00:05:39: Using text output
00:05:42: ++++++++++++++++++++++++++++++++++++++++++++++++++++++
00:05:42:   New Scene
00:05:42: Using text output
00:05:42: Using Slide Show
00:07:47: Total frames encoded: 8230, total frames duplicated: 6 (0.07%)
00:07:47: Total frames rendered: 8255, number of late frames: 0 (0.00%) (it's okay for some frames to be late)
00:07:47:
00:07:47: Profiler time results:
00:07:47:
00:07:47: ==============================================================
00:07:47: video thread frame - [100%] [avg time: 3.761 ms] [children: 81.5%] [unaccounted: 18.5%]
00:07:47: | scene->Preprocess - [76.9%] [avg time: 2.892 ms]
00:07:47: | GPU download and conversion - [4.63%] [avg time: 0.174 ms] [children: 4.25%] [unaccounted: 0.372%]
00:07:47: | | flush - [3.91%] [avg time: 0.147 ms]
00:07:47: | | CopyResource - [0.213%] [avg time: 0.008 ms]
00:07:47: | | conversion to 4:2:0 - [0.133%] [avg time: 0.005 ms]
00:07:47: Convert444Threads - [100%] [avg time: 1.26 ms] [children: 99.4%] [unaccounted: 0.556%]
00:07:47: | Convert444toNV12 - [99.4%] [avg time: 1.253 ms]
00:07:47: encoder thread frame - [100%] [avg time: 3.13 ms] [children: 0.128%] [unaccounted: 99.9%]
00:07:47: | sending stuff out - [0.128%] [avg time: 0.004 ms]
00:07:47:
00:07:47:
00:07:47: Profiler CPU results:
00:07:47:
00:07:47: video thread frame - [cpu time: avg 2.538 ms, total 20953.1 ms] [avg calls per frame: 1]
00:07:47: | scene->Preprocess - [cpu time: avg 2.144 ms, total 17703.1 ms] [avg calls per frame: 1]
00:07:47: | GPU download and conversion - [cpu time: avg 0.054 ms, total 453.125 ms] [avg calls per frame: 1]
00:07:47: | | flush - [cpu time: avg 0.045 ms, total 375 ms] [avg calls per frame: 1]
00:07:47: | | CopyResource - [cpu time: avg 0 ms, total 0 ms] [avg calls per frame: 1]
00:07:47: | | conversion to 4:2:0 - [cpu time: avg 0.001 ms, total 15.625 ms] [avg calls per frame: 1]
00:07:47: Convert444Threads - [cpu time: avg 1.416 ms, total 23312.5 ms] [avg calls per frame: 2]
00:07:47: | Convert444toNV12 - [cpu time: avg 1.411 ms, total 23234.4 ms] [avg calls per frame: 2]
00:07:47: encoder thread frame - [cpu time: avg 2.557 ms, total 21046.9 ms] [avg calls per frame: 1]
00:07:47: | sending stuff out - [cpu time: avg 0.011 ms, total 93.75 ms] [avg calls per frame: 1]
  Pin: Capturar
  Pin: Estático
Device: SparkoCam Video Source
  Pin: Capturar
Device: SparkoCam Virtual Webcam
  Pin: SparkoCam
Hey all, been trying to set up my StarTech USB2HDCAP
http://www.startech.com/AV/Converte...Capture-Device-1080p-HDMI-Component~USB2HDCAP
Been able to get it working with the built in software, trying to get it working with just OBS (not using screen cap)
Getting a red screen with a few different resolutions and 30 fps. It appears as "Fujitsu H5x Video Capture".
Here is the copy from the DirectShow Pin List and Caps
Device: Fujitsu H5x Video Capture
Pin: Capture
category: {6994AD05-93EF-11D0-A3-CC-00-A0-C9-22-31-96}
Pin: Audio Out
00.) major type: MEDIATYPE_Audio
sub type: MEDIASUBTYPE_PCM
format type: FORMAT_WaveFormatEx
Pin: TS Out
category: {A886121C-152E-45CA-8E-C0-15-95-80-33-C4-18}
sub type: {F4AEB342-0329-4FDD-A8-FD-4A-FF-49-26-C9-78}
Status
