Bug Report Exiting Studio mode causes rendering problem
w00t
I have experienced what appears to be a rendering issue with obs under Linux. I have tried both the Ubuntu PPA and a freshly compiled version.
The problem is that entering and exiting studio mode causes the UI to get weird. When clicking "Studio" the second time, the UI elements and the right scene view stop working. The scene in the left window appears to be scaled back up but only shows in the left scene view that was setup when I clicked on "Studio" the first time.
I have attached a screenshot right after clicking "Studio" the second time to exit studio mode.
I can force the view to be fixed by adding and removing a source (like a window capture). The view is not fixed if I only change the order of sources or turn the view of sources on and off.
Thanks,
wt
It looks exactly what I see. I right-click and choose Fullscreen Projector (Preview) then exit, and OBS preview returns to OK state. (lubuntu)
I see the same thing, has there been anymore done on this? Sure would be nice not to have to go
through the additional steps just to get back to the single screen.
Same issue for me with today's git hub repository
Resize or enter/exit studio mode fills obs window with garbage
Fedora 25 fully updated using Xorg gnome session
Tested (and confirm fail) with nouveau and intel graphics driver
EDIT:
Just removed an old "export LIBGL_DRI3_DISABLE=1" from my startup script and everything goes fine
