Elgato HD60 S+ not working on Linux
jcm
Hi, I recently switched to Linux from Windows, and I bought a used HD60 S+ online when I saw that my current HD60 S isn't compatible with Linux. I'm not getting any luck with the S+, though, and I'm not sure if the capture card or my setup is to blame. The capture card lights up when connected, and the system recognizes the S+ correctly as far as I can tell, but nothing I do gets any signal at all (except for a rare dark green flash). The signal from my Switch isn't passing through to my monitor either. Any ideas? Thanks!
Relevant terminal output from lshw in case that's helpful too:
*-usb:1
description: Video
product: Game Capture HD60 S+
vendor: Elgato
physical id: 2
bus info: usb@4:1.2
logical name: card1
version: 0.01
capabilities: usb-3.00
configuration: driver=snd-usb-audio maxpower=800mA speed=5000Mbit/s
I suspect it might be down to the format you've selected for the device? OBS is clearly picking it up as a V4L2 input.
Maybe it is struggling for bandwidth with the USB: 1920x1080 YUYV at 60FPS is going to require about 2Gbps at a guess. USB 3 can technically handle 5Gbps but it depends what is going on.
