Echo from Mic Only When Streaming (Not Recording) - Multiple Mic Setup
rcoon
Afternoon all,
So I've scoured Google and noticed numerous others with the same issue but theirs appears to be pertaining to a different monitoring issue. I've attached screenshots of my entire setup/settings and even when removing various things from the audio devices and adding them individually into scenes it still hasn't resolved the issue. Basically I have a wireless mic setup and a Yeti via USB. All sounds work perfectly, however when I speak through the Yeti while streaming specifically, there is serious echo. If I run the identical setup and record instead, there is zero echo, so I know its not that the wireless mics are picking up my voice.
