Bug Report Chroma Key Pick Screen Color Bug?
SOLUTION:
So the issue could be that you have your OBS hidden from screen capture, if thats the case then it wont recognize colors on the window. To turn it off you just want to go to File in the top left on the window, click settings, and one of the first options in the general tab should be "Hide OBS windows from screen capture". Make sure that is unchecked, click apply, and it should work
SOLUTION:
This must be a Windows thing; the problem seems to only be on Mac. The preference in the picture is not on the mac version.
Hi everyone,
I have an old version of OBS I just installed it on 27.2.0. to see if it's there and it is. It works as expected. However, I am currently on the most recent 32.0.0. beta 2 and wish I could use it with the most current. Anyone figure it out?
