bug at 60 fps
FranckB
Member
little problem. OBS crash if I choose 60 or 59.94 fps. At 30fps, same settings, no problem - For recording (no streaming)
4K 60 or 59.94fps / 60000 kbps ---> OBS crash after stop recording - see log
4K 30 fps / 36000 kbps --- > no problem
If someone knows how to interpret the attached log, I would like to understand the problem. Hardware problem? or OBS?
i9/32go RAM/AMD Radeon VEGA 4go - Windows 10 up to date
OBS 28.0.3
Thanks.
Does every crash log start with that unknown entry in the dump
Looks like it probably is a driver issue Could try reinstalling the GPU driver Might want to run DDU for a full clean-out beforehand
You probably need to do a clean GPU driver install:
hello
Thanks for your help. I applied the DDU procedure. Without success. OBS still crashes at 60fps.
Well, I think I certainly touch the limits of the AMD graphics card:
Two screens, one is 3K and the other 4K; capturing the one in 4K at 60fps with the h264_amf (libx264) @48000 Kbps encoder output in MKV is probably too much!
OBS tells me that the encoding is overloaded.
In short, this is not a reason for OBS to crash...
I don't know what other encoder to use (GPU)...
  • Crash 2022-10-31 11-38-03.txt
Please post a log file as you showed in another thread you're using a custom ffmpeg codec inserting custom parameters.
And yes, it may be the reason for the crash of OBS.
Get the advice and keep it on simple output mode and select one of the presets settings for recording.
Whatever settings you are using end up causing the crash.
I don't have any crashes in standard simple and advanced mode, @60fps, but overloads in 4K and not on lower resolutions.
In "FFmpeg custom output" mode in 4K@60fps, crash after capture... (no crash in 1800p resolution...)
