Question / Help Black screen on every capture mode
ChoHanjun
I wanted to record a video but when I chose display capture, it was black and so I checked my nvidia control panel and saw it was already on Intel GPU. So, I tried it with another capture mode but same result. Theres another thing I realized which was that the resolutions are 0,0 https://obsproject.com/logs/w06Xm6C5vlNDyK-b
If you've got the 1909 Windows update, you need to change OBS' GPU settings in Windows, not in the nvidia software.
https://github.com/obsproject/obs-studio/wiki/Laptop-GPU-Selection-Windows-10
20:08:59.621: - scene 'Scene':
20:08:59.621: - source: 'Game Capture' (game_capture)
20:08:59.621: - source: 'Display Capture' (monitor_capture)
Are you possibly covering a functioning display capture with a non-functioning game capture, obscuring it? You should not have these in the same scene anyway, it is non-performant and can cause interference.
You won't be able to window capture Chrome unless you turn off hardware acceleration in the browser.
Most Microsoft Store apps can't be captured. I don't think Edge can be.
Thanks! Changing from the settings of the display worked!
