atkAudio Plugin
atkAudio Plugin 0.32.3
Updating to the pre-release of .31 broke my audio output using the asio interface plugin. I rolled back to 30.1 and it fixed it but I'm curious if this was an issue on how I have to have 31 setup or some sort of bug. Assistance appreciated.
There is this in works. https://github.com/atkAudio/PluginForObsRelease/releases/tag/0.31.1 It fixes some reggression bugs in 0.31.0. But in general there should not be audio routing changin/breaking changes between 30 and 31.
I'll update and report back. The routing plugin just isn't passing through any of the audio that's on the 2 virtual channels in .31. I'm using an Apollo 8x and when rolled back it immediately starts working. Made sure virtual channels are selected in the inputs.
Does the Apollo work at all, even if you create new empty scene with .31?
Spoke too soon, yes this worked great for about 1 hour on stream, and then the DeviceIO just dropped the audio signal, opening it up in filters and unchecking / rechecking the virtual outs made it connect and work again. If this info is helpful
is it ASIO device?
This version has broken the Asio Deviceio again for OBS. No audio activity when adding and reselecting the Virtual channels being used on my apollo... Reverting back to previous version even with the bug that causes disconnect mid stream.
Yes, with new version you need to reconfigure your DeviceIo instance.
I reconfigured it and reboot, the audio is working now, however it's clipping at -15 in the mixer of OBS instead of at 0.0 which the output is from the Apollo console (and previous versions of ATK). I noticed also increasing Output Gain in the atk DeviceIO is INVERSELY effecting the output volume. ie increasing output gain by 10db positive is decreasing the output level of the OBS mixer output.
https://github.com/atkAudio/PluginForObsRelease/releases/tag/0.31.5 can you try this
This resolved both issues. I haven't tested more than routing and gain, but it's accepting audio from ASIO and also at the correct levels / gain directions.
