스트리밍중에 끊김 현상이 발생합니다
Unhandled exception: 80000003
Date/Time: 2026-06-09, 17:03:02
Fault address: 7FFD536BFB20 (c:\program files\obs-studio\obs-plugins\64bit\libcef.dll)
libobs version: 32.1.2 (64-bit)
Windows version: 10.0 build 26200 (release: 25H2; revision: 8524; 64-bit)
CPU: AMD Ryzen 5 9600X 6-Core Processor
Thread 65F4: CrBrowserMain (Crashed)
Stack            EIP              Arg0             Arg1             Arg2             Arg3             Address
0000002133C4E0A0 00007FFD536BFB20 00003B1C006532F0 0000002133C4E650 0000002133C4E650 0000002133C4E5A0 libcef.dll!0x7ffd536bfb20
0000002133C4E520 00007FFD536BF785 0000002133C4E650 00003B1C00D72710 1FFFFFFFFFFFFFFF 0000000000000000 libcef.dll!0x7ffd536bf785
0000002133C4E600 00007FFD536BFB39 000000000000000C 0000000000000003 00003B1C008DFEC0 00007FFD5028594F libcef.dll!0x7ffd536bfb39
0000002133C4E630 00007FFD51D2999E 0000002133C4EC00 00003B1C000174A0 0000000000000001 00003B1C008DC470 libcef.dll!0x7ffd51d2999e
0000002133C4E790 00007FFD51D264B4 00003B1C01061240 0000002133C4EC00 00000000C0000005 00003B1C00E84940 libcef.dll!0x7ffd51d264b4
0000002133C4E7C0 00007FFD51D249CB 0000002133C4E9E0 0000002133C4E8C8 00003B1C01061240 00003B1C01061240 libcef.dll!0x7ffd51d249cb
0000002133C4E800 00007FFD51D31FD6 0000000000003744 00003B1C00A94AD8 0000000000003744 00003B1C00A94AD0 libcef.dll!0x7ffd51d31fd6
0000002133C4E970 00007FFD51D335E0 0000002133C4EC00 000022DC0024D260 00003B1C00E88FA8 00007FFD4FEC0176 libcef.dll!0x7ffd51d335e0
0000002133C4EAF0 00007FFD51B4E2C4 0000002133C4EC01 00007FFD4FE4E3CD 0000000000000000 00003B1C00F48FD0 libcef.dll!0x7ffd51b4e2c4
0000002133C4EBE0 00007FFD4EC78C1D 00007FFD593DB9AB 00003B1C00F48F18 00003B1C000174A0 0000002197F1FCFF libcef.dll!0x7ffd4ec78c1d
0000002133C4EC50 00007FFD4FE5E5AB 1FFFFFFFFFFFFFFF 00003B1C00F48E00 00003B1C000174A0 00007FFD4FE52C43 libcef.dll!0x7ffd4fe5e5ab
0000002133C4EDE0 00007FFD4EAEDB5F 0000002133C4F210 00007FFD53737D20 00003B1C010632C0 00007FFD4F74B40B libcef.dll!0x7ffd4eaedb5f
0000002133C4EE70 00007FFD4EAEE828 0000000000000000 AAAAAAAA00035B48 0000A47AE39A6638 0000000000000000 libcef.dll!0x7ffd4eaee828
0000002133C4EF50 00007FFD4FE606C0 AAAAAAAA00035B48 000022DC002B5780 0000000000035B48 00007FFD4FEC6E79 libcef.dll!0x7ffd4fe606c0
0000002133C4EFC0 00007FFD53738F37 0000000000000000 00000000000000E9 0000002133C4F248 00007FFD4FE407BA libcef.dll!0x7ffd53738f37
0000002133C4F1A0 00007FFD4F736B15 0000000000000000 0000000000000004 000022DC00221330 0000002133C4F248 libcef.dll!0x7ffd4f736b15
0000002133C4F1D0 00007FFD4FE64D2C 0000A47AE39A7B08 0000000000000001 000022DC00221330 0000002133C4F450 libcef.dll!0x7ffd4fe64d2c
0000002133C4F260 00007FFD4FE3F03D 0000002133C4F368 00007FFD4FE39250 000022DC00221270 0000002133C4F4C4 libcef.dll!0x7ffd4fe3f03d
0000002133C4F300 00007FFD4FEC5D07 000022DC00221258 00003B1C0009A9A0 000022DC002211A0 00007FFD4EC50228 libcef.dll!0x7ffd4fec5d07
0000002133C4F540 00007FFD53682E05 0000002133C4F6A0 00007FFD593D1B28 0000000000000008 0000000100000000 libcef.dll!0x7ffd53682e05
0000002133C4F600 00007FFD4EA511CE 0000002133C4F760 00007FFD5028594F 0000000000000000 0000000000000000 libcef.dll!0x7ffd4ea511ce
0000002133C4F670 00007FFD4EC4E916 0000000000000008 0000002133C4F810 0000000000000038 0000002133C4F810 libcef.dll!0x7ffd4ec4e916
0000002133C4F6F0 00007FFD4EA6A37F 0000000200000000 0000003100000001 0000002133C4F890 0000000000000000 libcef.dll!0x7ffd4ea6a37f
0000002133C4F7C0 00007FFD4DE806E6 000002110F5F26D0 0000000000000000 0000000000000000 0000000000000000 libcef.dll!0x7ffd4de806e6
0000002133C4F860 00007FFDBC09EF3E 0000000000080001 000002110F515CA0 0000000000000000 0000000000000000 obs-browser.dll!BrowserManagerThread+0xe
0000002133C4F890 00007FFDBC0A275B 0000021100000000 0000000000000000 0000000000000000 0000000000000000 obs-browser.dll!std::thread::_Invoke<std::tuple<void (__cdecl*)(void)>,0>+0xb
0000002133C4F8C0 00007FFDBC0EE022 0000000000000000 0000000000000000 0000000000000000 0000000000000000 obs-browser.dll!thread_start<unsigned int (__cdecl*)(void *),1>+0x5a
0000002133C4F8F0 00007FFE548DE957 0000000000000000 0000000000000000 000004F0FFFFFB30 000004D0FFFFFB30 kernel32.dll!0x7ffe548de957
0000002133C4F920 00007FFE553E7C1C 0000000000000000 0000000000000000 0000000000000000 0000000000000000 ntdll.dll!0x7ffe553e7c1c
OBS browser source crashed. The error itself - "Unhandled exception: 80000003". I think here it means - "no resources to complete the task". In my opinion likely, because of memory paging errors (speed error or PC low on free memory; CPU requires that all data to be in the RAM before it can process it but requested data was not yet loaded into the RAM, so there is crash; take in mind that OS constantly pre-loads into the RAM everything you touch or work with).
Would be interesting to see if lower number of cores/threads CPUs crashes more or less frequently with the Browser sources. Each new process consumes RAM, and memory bandwidth - it has the limit.
General RAM consumption can be monitored via the Task Manager during the streaming/recording event. The "paging" errors can be monitored in the Resource Monitor > Memory tab > Hard Faults column (take in mind that the "paging" errors are time depended, so only peaks are important; enabled the paging file or not - doesn't matter; despite the naming of the column it is not about the hardware malfunction, it is about the speed and free space).
